I don’t know but it looks like the bolts were too short ( from left nut pix) and didn’t have room for at least flat washers. It’s not a high load block but still . Should have done it myself .Dang, I wouldn't mind a backing plate and some threading into the nylocks. Least there's some sealant?
So frustrating isn’t it? A basic job and the yard screws it up. 5 extra minutes to locate the right length bolts and some fender washers…Should have done it myself .
.. and disappointing. Makes you wonder what other shortcuts were taken on the rest of the project.So frustrating isn’t it? A basic job and the yard screws it up. 5 extra minutes to locate the right length bolts and some fender washers…
AGREED! Perhaps you can contribute to your rigger's education. Use of a proper fastener is prerequisite to achieving a proper job....basic hardware store knowledge I would think.I think you need to call that rigger back for a redo
This was something I certainly would do but it was part of an overall rigging replacement project which included replacing the furler. It made sense for them to install the lead-in block because the correct operation/ setup of the furler is their responsibility. Knowing what I know now , I would do things much differently.While working on boats this weekend, it was said by several passer-bye boat owners, "if you have it done, they will likely do the same job but worse". While I don't want to believe that for the jobs I can't do, re-bedding portlights and stanchions are not fun but definetly worth my time to do.
Early this year my mast was pulled and had all of the standing rigging, hardware, halyards, you name it was replaced. It was well overdue and after some of the winds I was sailing in on the bay this year it was well worth it at least for the peace of mind. The riggers for the most part did a fine job but I still called them back at least four times to fix little bothersome issues that I didn't think were done right or didn't look right to me. When a so called "pro" does a job, on your boat, house, car, whatever...if something doesn't look right, even if it is, you should call them on it at least for your self-education and at most because something may not be done right and it was either over looked to the rigger who had just broken up with his girl/boy friend the night before and was in a foul mood when he or she worked on your boat. You're paying the freight on it and you have that right. Don't be timid because you think that they know better.AGREED! Perhaps you can contribute to your rigger's education. Use of a proper fastener is prerequisite to achieving a proper job....basic hardware store knowledge I would think.
Not sure what I'll do in my retirement years....apparently I'm overqualified to be a rigger?!
I agree 100% with everything on here. Unfortunately it mirrors most of my limited experience having "professionals" work on my boat. My strut replacement project was a pleasant exception, but I was heavily involved.
One thing I've noticed is the discrepancy between good owners and the staff they are able to employ. It's difficult to find good people, pay them appropriately, charge a reasonable amount, and keep a business above water. I've frequently seen well intentioned owners trust projects to employees who have no clue what they're doing and the owners don't have the time to follow up on everything going on. There's not excuse for this work, but it might help frame a conversation with the yard you're working with. Hopefully the owner can take it as a learning opportunity for themselves and their staff.
If the owner did the work themselves or knowingly let this go out the door, then that's a whole different
Good answer.The best answer I have found is, "a sailboat is not a car."
