Westerbeke 10 Two - Help Identifying Starter Solenoid Connector
KS Dave
Dastardly Villain
I'm currently trying to go through all my dodgy engine wiring and get things documented and connected reliably. All too often, I've hit the starter and nothing happens.
To that end, I'm working on what I need to re-crimp on new connectors and run new wire where applicable. I've come across this one on the starter solenoid. I don't know what it's called so I can acquire another one. It looks like a right-angle terminal connector, but I didn't know if that's it or if it has a special name. It's sold as part of the wiring harness, which is overkill; I just need the connector. Appreciate any help.
Remove the connector and measure the width of the spade stud it fits over. Any female spade connector of the same size should work, angled or not.
