Mack8964
Is it possible to add access ports to plastic water tanks? I have two tanks with tiny 1 inch openings that look welded shut and one with a ~ 4" opening that is also welded shut (see pics). I took them out last weekend and cleaned what looked and smelled like a grade school science project gone bad. I'd just like to be able to get inside with a scrub pad to finish the job. During removal I discovered the v-berth tank grey supply line was loose and fell off before I took the tank out. At least I know where the water was coming from.
