Wanted E28 to 30
ADSHRIV
Looking for a clean (non-project) Ericson in the 28-30 ft. range. Plan to keep it in the Chesapeake Bay area. Your 1st email should be an accurate, detailed description of the boat. ADShriv@Verizon.net
Have you contacted the owners of these Ericsons, listed in this forum? I note that there are some on the East coast, and trucking costs would be reasonable to bring it home...
Hi,
Have recently retired & thinking about selling our Documented 1971 E 29, with the following equipment to facilitate relocation:
Sail inventory:
· two year old North Main
· Hood 110
· North 120
· North 150
· North 170
Winches:
· 2 Lewmar 40’s
· 2 Merium 25’s
· 1 Barient 18
· 1 Lewmar 8
Note:
1. All sheets & halyards led to Cockpit
2. Forspar telescoping pole
3. Yacht Specialties Wheel Steering
Power:
· Universal M18 Diesel, with aluminum tank
Cabin:
· Upholstery:
1. Main cabin redone about 5 years ago
2. V Birth last year
· Stereo
· Stove:
1. Gimbaled 2 burner Alcohol
2. Butane portable
· Pressure Water
· Raritan Head with Holding Tank
· Thru Hulls replaced with Ball cocks
Lewmar opening ports
110 Shore Power
Safety:
· 2 Anchors & 600 ft ½ inch line, + an additional 300 ft ½ inch
· Balsa Life Raft, Horseshoe, 2 life rings, jackets etc
· MOB Strobe, flairs etc
· Handheld & stationary VHF
· Electric & manual Bilge pumps
Stainless swimm ladder
Boat is located in the water at our home & dock at:
51 Island Drive
Brick, NJ 08724
pH: 732-892-2436
If interested, give us a call.
Paul & Anne Marie Huch
Seth
Ericsons
Happy Hunting! Both are great boats-with my nod going to the 30/30+. The 28 is a 30 with the back end chopped off (basically), and as such is not quite as well balanced. It is also a bit more tender, but if you find a great deal you will be very happy-The 28's are a bit more demanding in terms of weight placement and mainsail design (you really need a flat main). The 30's are simply better all around performers (especially in breezy conditions), but again both are great.
Best of luck and feel free to use and abuse us in your search!
Good times,
Seth
