I have a E29, the vhf works but very limited distance, has anyone upgraded or changed their vhf to get more signal distance? without going up the mast and changing the antenna? Thanks
Depending on the age of the antenna wire, I would suspect the coax is bad, as well as the antenna.
Have you taken the radio to a shop for bench testing? Our local marine electronics shop does this at no charge...
Loren in PDX
I'd also check the connections on the coax - I've found these not installed well on a couple of boats and replacing them seemed to help quite a bit. It's easier than the entire coax, but in the end that might be the right answer (after gettting the radio bench tested).
