Fault finding from afar
Hi Tom, your time and replies are most welcome and appreciated.
Update.
2 new batteries fitted, AC DELCO DCM27 Voyager II series.
Battery breaker switched on to batt 1 or 2 or both. Batt voltage 12.5 VDC at batt terminals.
Ign switch off, terminals voltage, 12.4VDC.measured across pos and RPM neg terminals.
As soon as Ign switch to on, voltage drops to 0.5 VDC.
Of course, no fuel pump, no oil light, no nada.
Batts and DC cct, stereo, interior lights etc all still good and working. Batts 12.5VDC across batt terminals.
Ignition key off, Alternate 12V supply jumped into negative terminal on Ammeter (at back of ignition panel) and pos terminal on Glow plug GP.
Ignition key switched on, fuel pump running, oil lamp illuminated, all lights in gauhe's on start panel illuminated.
GP button pushed, voltage dropping on alternate source qhilst GP cct energized, after 20 seconds, GP button released, alternate supply back to 12V.
Return system back to normal.
Switch battery breaker on both batts. 12.4V as before across Ign pos terminal and negative terminal on Ammeter.
Turn on Ign key, immediate voltage drop to 0.5V.
Again, of course no Power for GP oil light or signal to start cct.
Following checked. Pos terminal on starter to earth 11.5V.
All terminals removed wire brushed or emery clean and replaced.
This irritating prob has been intermittent, to now not working at all.
You assumed I had 13V at battery when pushing GP.
When that was the case, all was good and engine would start normally.
Prob now is low voltage immediately on switching ign key on.
I am having difficulty tracing live (pos) (purple?) wire from ignition panel back to source. As I would lIke to replace with new.
I have also removed and had starter motor dished up.
I have also replaced the ignition key. No difference. Problem remains. Only to ensure that I need to learn this system onboard my newly purchased, Cannot get out of the marina E38. the previously un loved Merrimist.
Look forward to your fault finding suggestions from afar to assist me in getting this prob sorted.
Thankyou in advance for your time and help.
Merrimist Bermuda
