The side stays in my 1977 E-27 have gotten noticeably looser over the winter, and I'm concerned about material failure "somewhere". The boat was over-wintered in Connecticut in the water, uncovered. There is rot in the bottom of the plywood bulkhead panel between the head and the salon, but the head door closes fine and the area under the mast by the head APPEARS OK. I've also read about a "block" between the base of the compression post and the keel that might rot, but I haven't examined it closely myself (yet).
If I were building a sailboat, I'd never begin to consider using a water-sensitive material to hold up the mast, but I'm writing to find out if anyone knows exactly what holds the mast up and how to pinpoint the cause of the sagging stays. Is the compression post wood, and if so, what kind?
Thanks in advance!
Tanksalot
Thanks in advance!
Tanksalot
