My E27 is seeping goo. It would appear I have an epoxy problem around my handrails. This is the syrupy goo that has a vinegar smell. I'm fairly certain that is the water-diluted epoxy glue stuff. This was noticed just after the 12-inches of Ernesto water. Conincidence, or leakage?
There is a very small amount of goo that weeps from the crack, only a drop.
The goo is weeping through a spider crack in the cabin roof that is directly below the front screw of my port handrail (I'm going to snap a pic this weekend). The spider cracks appear to be a direct result of a PO (not you, David) attemping to "fix" the loose handrail problem by torquing the screws down tighter.
I recently rebedded the handrails and replaced the ferrules that were loose. This particular screw was one of those that did not need a new ferrule. At $5.00 each, this was a good thing The handrails are now *SOLID* and have a bed of 4000UV to keep them waterproof. New bungs, new varnish. Overall, a pretty darned good job if I do say so myself. Only cost me one screwdriver over the side!
OK. Now to my question: How best to address this?
The location of the goo worries me - perhaps I'm too worried? It is directly to the port side of my front vent. Obviously, the mast area is "uphill" of that as well. I cannot detect any "squishy" deck, so I am fairly confident that the deck wood is not spongy. Since the handrails were very loose (as in only held on by 2 screws on that side!!!) there has been quite a few seasons of water ingress at the handrail screw holes.
I'm thinking a moisture meter would be a good investment.... This is perhaps the best way I can think of to identify if the deck is really OK.
It would be logical to "probe" the extent of the goo by drilling some small holes in the cabin roof, but I'm not sure, other than a moisture meter, where and how many to drill.
The concern I have is deck de-lamination.
Thoughts?
Thoughts?
