There is no record in the detailed maintenance log for our boat that the previous owner of our 1984 E30+ ever rebedded the deck fittings--stanchions, pulpit, cleats, spinnaker pole holder, winches, deck organizers, hatches, etc. My check of these from inside the boat (inside the headliner, lockers, etc.) showed that two of the stanchion backing plates have a bit of rust on them, one of the four pulpit backing plates looks suspicious, but the rest look clean with no sign of any leakage or problem of any kind.
I am considering re-bedding everything, but this involves a significant amount of work, enlisting my wife for an extra set of hands when needed, and the risk that I inadvertently create a leak where there is none now, even though I tend to work carefully.
I am wondering about an alternative. I'm considering drilling a small hole from the underside of the deck near each fitting through the inside layer of fibreglass into the core, but not through to the deck, to check if there is any sign of moisture in the core. If it is dry, I'm thinking there would be no need to rebed that fitting, and the small hole from the underside would enable me to monitor and detect any sign of future leakage before much damage occured to the core of the deck. Of course if I find any moisture, I would rebed that fitting, and I plan on doing the fittings that show some residual rust.
Although my wife thinks I'm crazy for considering drilling holes in the boat (and maybe she's right!), the advantage of this approach is that I might only need to rebed a small number of fittings, and monitor the others until there is some indication that they are leaking. The disadvantage of this strategy is that I would be creating lots of small holes into the underside of the deck--I'm guessing there are at least two dozen fittings. And maybe by the time I detect a leak through the small holes, some damage might already have occured.
I would appreciate any thoughts on these options, and even better, any other strategies that have worked for you.
