windjunkee
This is a very esoteric question, but here goes: I purchased a used Kenwood TKM-707 SSB radio for the boat. For hooking it up, I bought a Shakespeare 23 foot antenna and an ICOM AT-130 Antenna Tuner/Coupler. I believe the grounding is good and the installation/wiring looks to be in order. I had the Kenwood bench-tested and it was fine.
However, when it is hooked to the tuner, I cannot get the tuner to work. It powers up, but it does not tune, thus, I cannot transmit. We have traced it to the transceiver-tuner connection, but the wires are new and we followed the manual to the letter for connecting one to the other.
My understanding is that when one dials to a desired frequency, the antenna tuner is supposed to go through a series of switches to match the antenna to the frequency. The process is supposed to take somewhere in the range of 15 seconds to tune the antenna but we get nothing. The transceiver theoretically, sends a low voltage signal or pulse to the tuner which tells it to start tuning. However, our set up seems not to be doing that. We tried to jury rig a bypass with a schematic we obtained through ICOM with similar unsuccessful result.
I have been told both that the ICOM AT-130 is a universal coupler designed to work with any SSB transceiver, and that the ICOM AT-130 only works with ICOM radios. Before I go out and buy a new ICOM, I want to exhaust every avenue to make the system I have work. Anyone have any ideas?
Jim McCone
Voice of Reason E32-2 Hull #134
Redondo Beach, CA
Jim McCone
Redondo Beach, CA
