Mark Tuccillo
I removed the starboard rear portlight, in which the PO had replaced the glass with Plexiglas. I had a local glass company cut a piece of 1/4" laminate glass and then sealed it in the frame with clear Silicone. The old gasket would not fit the glass properly, so the Silicone made sense.
I now need to re-install the frame, but I am unsure as what to use to seal the frame to the hull exterior. I was thinking of using 4200. Any suggestions out there???
Thanks.
Mark Tuccillo
1983 E28+ "Wing It"
Thanks.
Mark Tuccillo
1983 E28+ "Wing It"
