More about that rudder shape
Information that comes out of a thread like this getting hard to find around the 'net.
I will append (with permission) some more info I received from Timm Leslie, who races a Cal 40 and owns Danish Marine, a boat yard in Portland.
I sent this thread link along to Timm, knowing that his boat has a modified rudder, and his reply was educational (well, IMHO, at least). I learned some new trivia and hope you enjoy this as well.
_____________________________
Aloha Loren,
The Olsen is suspiciously similar to the two Carl designs that I commissioned for California Girl Cal 40 and Freewind a Cal / Ron Holland designed ½ tonner.
I also asked him to look at A Bob Smith design on Stan Honeys Cal 40, while it was on the hard at Alameda “Svendsens” – similar concept- carbon fiber post with rudder bearings...
I had Tuttle “Water Rat" make the plug, and then sent the plug to Foss to make a mold for our 24ish Cal rudders for the Yahoo Cal group. Dennis Grant of Vangmaster watched over the project, and did the float test and test fit of the rudder. The rudder had positive buoyancy, and #1 had the wrong post angle. They remade the rudder and I passed the fit test.
We had the new Cal rudder made with a next size smaller rudder post, with a greater wall thickness. This allowed us a narrower profile, and a neater NACA shape. To facilitate the rudder getting slender at the tip, the rudder post was flattened in a press from circular to nil flat at the tip.
The rakes were mechanically inserted into holes in the shaft to avoid welding issues.
Dennis Grant selected and machined Nylatron bushings for the top and bottom of the rudder tube, so the smaller diameter post, could fit in a standard rudder tube, very simply. Nylatron is a tradename for a family of nylon plastics, typically filled with molybdenum disulfide lubricant powder. It is used to cast plastic parts for machines, because of its mechanical properties and wear-resistance. We discovered that the Nylatron swelled @ 3% in water so my #1 was initially very stiff, so we added a zerk fitting to the rudder tube and put trailer grease in there, It eventually loosened, and now is very perfectly worn to fit, with no play.
A stainless split machined insert was made so the smaller post could fit into the standard tiller head.
At the end, my custom rudder one off was @$5k, making 20 plus of them at one time reduced the cost to @1.2k.
Foss kept the mold, and has been using it on their line for a number of boats.
Carl died, and so his royalty agreement disappeared (was “forgotten?”).. at one time it was $300 per rudder.
It was a great project at the time, we had a new Class rudder accepted, the boat had the benefit of greater and easier handling and restored confidence.
Numerous other fleets have the benefit of Carl’s brilliant masterpiece, and may never know it.
Thanks for stirring fun memories!
Kind regards,
(¸.·´ (¸.·' ( ......….-_/)
Timm Lessley
Lessley Marine, Inc.
Dba Danish Marine
152 NE Tomahawk Island Drive
image002.pngPortland Oregon
45 36.257’N
122 39.889’W
Timm@DanishMarineCo.com
www.DanishMarineCo.com
_______________________________
And there we are!
More rudder lore. Elsewhere on this site there is a picture that I recall of a red E-35-2, fitted with a rudder that looks just like the "Cal 40 blade" Grizz' Olson 34.
Regards,
ps: full disclosure: Timm's yard has done good quality work on our Olson
