Hello All.
I have a 1984 38 which will have new rigging installed this winter. Due to their inherent design flaw/weakness at the bend, I'm wondering if anyone has ever replaced the shroud t-balls with tangs? I'm considering this but do not know how this would best be done.
I was thinking (hoping/dreaming) that I could simply put a bolt through the existing backing plate. Either a bolt completely though the mast or even a short t-bolt at each tang. If this is even plausible one concern I have is if I put a bolt though a flanged bushing so there's no load on the threads, the bolt diameter would be significantly smaller than the diameter of the t-ball. Is this an issue, or would the combination of a bolt in a flanged bushing be equivalent to a bolt the diameter of the bushing?
Any thoughts in general would be greatly appreciated.
Matt.
Matt.
