Replacement head pump
CSMcKillip
Replacement head pump-!!!!photo added
Has anyone replaced the head pump without having to re drill the holes and attachment? Is there a pump kit? My little nylon nut has a crack and trickles water down the pump.
chris
CSMcKillip
Please look at the attached photo and tell me who made this head if you know. I would like to find replacement parts or a new head that will replace this one without having to cut a bunch of holes and re route plumbling
attachment.php
CSMcKillip
You would not believe what comes up when you google search for "head pump replacement"
Thanks for any input
Best guess (looks like..) :
Wilcox Crittenden HeatMate toilet.
(found via a google search for images of marine heads)
Headmate head by Wilcox Crittenden
Chris, Once again Loren hit the nail on the "head". It is indeed a Wilcox Crittenden Head-Mate. I recently removed, rebuilt and replaced the exact same unit for a friend in her boat. Cheers, Glyn Judson, E31 hull #55, Marina del Rey CA
CSMcKillip
Replaced or rebuilt- I have been reading now for the last two hours on the headmate, I can get a full replacement pump for 145.00 and go on down the road or replace the entire unit. My pum has a crack in it down the start of the case that squirts water out and tends to hit my son.... I think he really try's!!!! Any way I have to replace or repair the unit pump. I can "rig" it up with some good old epoxy, or do it the right way and replace the pump itself.
But for another 1.5 boat units I could upgrade and found this pressurized unit interesting. http://www.defender.com/product3.jsp?path=-1|51|2234284|2234286&id=2598940
I really don't want to cut any more holes to mount but the pressurized water is right under the sink supplying the sink and shower.
