Strictly in the "FWIW" dept.... both our prior boat and this one have some common construction eatures in their basic wood cabinet and most corners where a 90 degree piece of wood meets another wood surface.
One the hidden (back) side there is a cleat. Sort of a square piece of wood about an inch by an inch... maybe a bit larger, and it runs down the whole joint.
The carpenter would then countersink holes in that piece on two sides and inset screws into each back side of the face material. You will not see these from the front or finish side. Sometimes in a high stress area screws will be driven from the front and the holes plugged.
I have found this method used even in hidden places way back in the lazarette areas in the stern sections where plywood panels met.
This is probably old hat to trained cabinet makers, but I found it interesting and i liked the inherent strength in the joint.
The EY shop would have been great fun to visit back in the day....
:nerd:
