Joerageous
Do you have to remove the rudder in an Ericson 38 to remove and repair propeller shaft?
Thanks for your response. Do you have to remove the cutlass bearing in order to slide the shaft past the rudder?
No. The shaft alignment is offset enuf to slide out the shaft with no problemThanks for your response. Do you have to remove the cutlass bearing in order to slide the shaft past the rudder?
thanks so much we are needing to have the repair done and the yard is thinking they have to remove the rudder to get the shaft out. Have a good day.No. The shaft alignment is offset enuf to slide out the shaft with no problem
