plumbing questions 35 II
admirals barge
hi all
1.just rehosed the sanitation system. it had a recirculation system and now its gone. the toilet is a par and it looks like a jabsco. are they one and the same ? because i have to rebuild the pump and i don't see par anywhere.
2. both water faucets are beyond repair. i would like to put dual action faucets in there place. i have a few questions that i'd love your input on.
a. will water flow thru the pump when using the hand pump and will it hurt the pump ? how would the pump effect the two hand pumps ?
b. if so then all i would need are 2 shut off valves at the hand pump inputs ?
c. if not then i would need a bypass loop and a y valve at each faucet ?
d. am planning on installing a 12v 120v insta hot in the galley that requires using the pump. would this also need a shut of valve when using the hand pump ?
thanks
happy sailing
greg
74 35 II # 325
wilmington,ca
