I have a 1987 E26 with a universal M12. I would like to replace the packing gland material for the prop shaft. I was able to loosen the packing gland nut however I can only slide it back about an inch before it hits the flange that connects the prop shaft to the transmission. This leaves me less than a half of an inch to try and remove the old packing material. Do I need to disconnect the shaft from the transmission? If i do this will the shaft slide back easily? I am pretty mechanically inclined however, I have never done this type of maintenace before and I am not sure if I should give this job to the yard. Any help would be greatly apprciated.
I would like to add that I have followed this web site for quite sometime and it is by far one of the best boat forums going. I have always like the Ericson sailboats since I was a kid. I finally purchase one two years ago and have enjoyed the boat very much. I mostly sail single, although my two young childeren have started to take some interest. The only add on that I have done so far was a new main sail last year. What a difference that made for performance !!
Thanks again for any help that you can provide.
