Chris Knudsen
Just when I had my A4 running like a top she has blessed me with another mystery problem. Here is the rundown:
Last week I was heading out for a quick little ride. On my way out of the harbor my boat started acting strange and engine speed started fluctuating (around 1500-1700rpm.) All of a sudden I heard some "popping" sounds possibly a backfire coming from the carb and then she stopped. Since I was in the channel I immediately unfurled the genoa and sailed away. Didn't have a chance to look at anything at that time. One our way back in she started right up with no issues. The next day she began to run hot. I noticed a significant amount of steam and little water coming out. She has always steamed a tiny bit once she is warmed up but this was a lot. Almost like I was spraying for mosquitoes. The temp gauge said 240 but I don't really trust it. It didn't seem that hot, I was able to put my hand on the head while running.
Boat Specs:
1971 Ericson E32
Atomic 4 (new style, believe to be original)
Raw water cooled (fresh water lake)
No thermostat and my bypass valve was closed.
Impeller only has about 30 hours on it and it was pumping what I believe to be a normal amount (10-15 ft spurt every couple seconds) up until a week ago.
Standpipe exhaust
Here is what I have done so far and what I have observed.
1. I did a vinegar flush to make sure my passages were clean. I have a T installed between my sea cock and pump. I closed the sea cock and put a hose on the T and into a gallon of vinegar. With the engine running it sucked the first gallon down no problem. When I switched bottles all of a sudden fluid started coming out that hose. It was a nice brown mix (must be the vinegar doing its job already) and some bubbles. Actually a lot of bubbles. Do you think these are exhaust or steam? I turned off the motor and let it sit for a bit. Then I started it back up and it sucked up the second gallon of vinegar. I let it sit overnight.
2. Day two, I go back and pull the hose off the manifold (to exhaust fitting) and added a length of hose going into a bucket. Started the engine and watched the flow. It seemed to be a nice steady stream. I got about 2-2.5 gallons of water at about 1,000 rpm in a minute to a minute and a half. It is the original style pump (202?) and I don't know the flow that that it is supposed to be but I imagine that I am close to spec. The water was slightly brown by I expected that.
3. Then I take the hose that leads to the water intake on the exhaust and blew through it. Didn't feel like any restriction at all. Hooked the hose back up.
4. Ran the engine again. Very little water flow and a lot of steam. Engine is running at 220-240 (again I don't trust this number though, needle is jumping around and head wasn't crazy hot.) This time I notice a trickle of water coming off the standpipe. My standpipe is wrapped in cloth so I don't know where the water is coming from. It could be the elbow at the bottom where it is dripping from or anywhere higher up?
Where do I go from here? I am going to check the oil and also compression. Help please!!!! I just want to go sailing.
(Cross posted on Sailnet and Moyer)
Boat Specs:
1971 Ericson E32
Standpipe exhaust
