outboard mechanic
Mark F
Does anyone know of a good outboard mechanic in Sausalito? The outboard on my boat starts fine, idles fine but will not run at higher RPM's without choking.
Rob Hessenius
Inactive Member
Quickleen
Mark- Before you take it in, run a Quicksilver product called Quickleen thru the motor. You just add it to the tank. I had the exact same problem and this is what the Mercury guy told me. I usually dont believe in the "snake oils", but this one worked for similar issues. Rob Hessenius
sleather
First, New Plugs?, old/bad plugs don't work @ higher RPM's.
Replace the Fuel Filter, "crap" in filter could be limiting flow!
Dump the "old" gas(how old?) & get new before you try Robs solution! That might work!
Good Luck, What is it????
Mark F
Thanks Steve and Rob. What are you guys doing looking down here?!
Hey Rob, sorry to hear about your job (or lack of) issue. I just finished reading your post.
sleather
Oops
Just comes up as a "New Post", never considered the source!
We have "outboards" too!
We're getting "early cabin fever" up here, winds, 24 gusting to 34, Tornado watch!
ChrisS
I used this guy to service an outboard on my last boat:
Marine Outboard
265 Gate 5 Rd
Sausalito, CA
(415) 332-8020
seanflinn
Inactive Member
Could be a number of things... water in carburetor... fuel pump...What make and model engine do you have? I might be able to help... I have worked as a outboard mechanic for a number of years now... more info would be helpful. Did you take a sample of your fuel to check for water...does the fuel bulb pump up and stay hard while idling? those are a few simple diagnostic tests that you can do, before turning your engine over to a shop that could charge you an arm and a leg... There I did it, I made my first post 1970 E35 2 #124 :egrin:
Erich
Mark,
I had the exact same problem with my Merc 5 hp 4 stroke this spring. Does yours run at full trottle for 5-10 seconds and then die off if you can't get it into idle quickly? After draining the carb multiple times looking for water and disconnecting the fuel hose I took it into a shop. They sprayed something into it (like carb cleaner but it was a Mercury product) and that freed whatever had stuck closed. Could have saved myself a lot of time and a few dollars by doing it myself.
Now I'm wondering what is the best way to winterize these small outboards. The manual says to drain the carb but that was how the motor was stored last winter. A friend with a Honda 5 hp used to have the same running problem until he left gas in all year long. Started easily for 4 springs after that.
Good luck
Erich
