Oil leak... in pan under engine
rhewitt
about a pint of engine oil in pan yesterday... Checked oil and it was a little over full. Looked at log and yes one of my Sea Scouts added a Qt last week.
could not find drips or leaks until started and then our mechanic says from the oil switch. On line I found a note about the relief valve, for when there is too much oil pressure. I will take another look on Sun.
Any one with input on this type of leak on a Universal 25xp? It seems to be right above the starter solenod.
rhewitt
never a happen to you...?
I sure hope it never happens to anyone else, just thought maybe someone might have some input. As to where it is coming from and how to fix.
Shadowfax
Isn't this in the area of the oil filter? Is that loose? Also if it was overfilled it could be out of the breather, but that is on the other side of the engine as I recall
