Murphy's Oil Soap Versus That nasty black foam stuff
Here's a tip for cleaning that nasty black foam off of the teak in the engine compartment and on the cabin soul as you track it all over the place when you service the engine. Try Murphy's Oil Soap. First, scrape as much of the foam off as run can with a putty knife. Then put Murphy's on full strength, let it soak for several seconds, then rub it off with wet paper towels. It works great. I even used the Dollar Store generic version.
We're currently rehabing some of the sound deadening material also. On the last boat I used the West Marine product at about $10/square foot. Last year the Sailors Solutions guys at the Annapolis Sailboat Show gave us (free) one of their one square foot panels. It also costs about $10 per square foot.
The West Marine stuff had a shiny reflective coating (for heat), a high density foam layer, a thin heavy layer of something, thin foam layer again, and finally a peel off sticky backing to hold it to the walls. In addition there were a few special washers and fasteners.
The Sailors Solutions product has a shiny reflective coating, a thin heavy layer of something, a high density foam layer, and a peel off sticky backing.
We're going to use the one square foot of the Sailors Solutions stuff and see how it does for durability compared to the West Marine product. At first look it appears that it isn't as likely to shed the shiny coating since it is attached to the thin heavy layer of something instead of the porous foam. I also like that it comes in one foot squares instead of a big bulky sheet. The engine compartment on small boats doesn't have many contiguous large areas, so one foot squares seem more appropriate. You can then order just enough for the job.
Sound-wise I don't know the difference. The Sailors Solutions product has the mystery heavy layer on the inside closer to the sound, so who knows what that does to sound absorption.
We probably won't know anything for a few years on our durability comparison so don't hold your breath. We have enough of the West Marine product left over to fix ours now, so I won't be buying anything this time. However, if I needed to buy some this time, I would get the Sailors Solution product based on the 1 square foot size and the shiny layer on the heavy layer.
-- neal
