My prop (Kiwiprop, 3-blade) broke a reverse roller, and wasn't shifting well to forward thrust. The boatyard says this can be repaired reasonably cheaply (boat is already hauled for other work), but suggests I might instead consider a new prop given what I say about how I want to use the boat.
They recommend (if getting a new one) a 3-blade bronze prop, either Gori or Maxprop. Someone else knowledgeable suggested Flexofold, but supposedly they do not have as good support availability in the US.
I would appreciate any opinions on:
- Should I just fix the Kiwiprop (a lot cheaper, but it's old, plastic, and has now failed once)
- If I change props, suggestions re: Gori / Maxprop / Flexofold (or something else)
- Fixed vs folding? (is fixed cheaper? I am told everyone does folding now)
- Anything else I should have in mind before talking to the prop people (yard has engine/gear ratio/shaft/etc -- I mean questions re: pitch, or who knows what. I am new to this and facing a $2.5k hit... figure I should ask here first
Many thanks (and Happy New Year)!
PS: details of boat/use model, if you want them:
- 1998 E34 with Yanmar 3GM30F
- 3-blade Kiwiprop is pretty old (at least 7 years, possibly (likely) a good bit older (boat is 1998))
- I sail / plan to sail a good bit in and off the approaches to the Golden Gate / SF Bay. This is a heavy ship-traffic/current/swell area at times, and also sometimes the wind drops out there and you end up motoring for a good few hours (like 5+) down to Half Moon Bay or up to Drake's Bay.
- I would like a prop with good thrust and reliable -- singlehand a good bit, not excited about problems.
- I do not race or care if I am competitive, but do enjoy that the boat sails pretty quickly (for its type/age). The Kiwiprop has not put me through the water at hullspeed -- been fine inside the bay, but not super fast. Upwind out of the marina (into 20+ kts) I can be creeping along at only 2-3 kts, which has made me wonder about it as a tool if I need it in bad conditions.
- A new prop is a lot of money for me; not super excited about the sudden new expense, but if I'm going to do it might as well do it earlier rather than later in my ownership of the boat.
