options
If you can live with a compromise, almost any spinnaker staysail or genoa staysail for a boat 33-37 feet will work or can be made to work with a reasonable re-cut. The spinnaker staysails will be better in most conditions (because they are lighter weight)except if you want to use it for super heavy air in lieu of the genoa. If so, only consider sails built as "genoa staysails".
OTOH, this is a sail you can have built for well under 2K, and have it built FOR YOUR BOAT and fit like a glove.....
good luck!
