EGregerson
I had fuel in the bilge the other day; a great thing to see...and smell. It had me going; checked the hoses and connections; everything seemed fine. cleaned out the bilge; got it shiny; and checked it the next morning; 6 or 8 oz of new fuel. So i put on my thinking cap and thot the hardest thots i could think. The 12' long 1 1/2" dia fuel hose goes thru the starboard locker down and under a partition; then behind the motor /tran assembly, and up to the tank. Crawling into the starboard locker and reaching way down there, I could feel fuel at the bottom of the hose where it turns toward the motor compartment. So I replaced the hose. But i realized in doing this that fuel has sat in the lower portion of that hose for 23 years. It doesn't empty. So over time, that is the point where fuel would permeate the hose (in the deepest darkest most inaccessible spot of course!) And that helps explain why high speed pumps burp the fuel back so fast. Question is; Is the low point in the hose there by design? to help reduce foaming before it flows into the tank? Or is just determined by the practicalities of the hull design?
either way, if your hoses are old, replace them before they develop mystery leaks... or worse. Happy Sailing
