Mmm... look at this tasty mast step and compression plate (1978 Ericson 35 MKII)
LeifThor
I can now speak directly to what is underneath the mast. A non-stainless steel plate underneath that is a very thin film of fiberglass mat underneath that is a half inch of ply underneath that is solid fiberglass to the top of the cabin where the post is running to the bottom of the hull. I chose to remove the plywood and I’m gonna be adding G 10 to replace both plywood very thin film of fiberglass and steel plate.
tenders
Innocent Bystander
Another mast step repair for your consideration.
LeifThor
Thanks! Skimmed but will read through it slowly and carefully before proceeding. I also like the kiwi grip solution as part of it.
kdenny
I have an 74 E35-2 and will have to do the same in the near future. So far this some good insight. Thank you!
