Mast Height
Some of the Ericson documents are contradictory on the mast height of the 35-3 when I tried to figure it out. When the mast was out of the boat, and the boat was on the hard, I tried to measure everything to determine how much room we needed for our boat with windex and VHF. The number I came up was 53 feet with the possibility that the VHF might touch. There is probably a small variance per boat based on waterline, mast rake, and masthead gear.
I had a friend way-back-when that went under a bridge backwords so he could check out the height with the VHF (which would bend) before it could knock out his expensive anenometer.
