There is a lot of friction if you pass the line trough the reefing eye as shown in the diagram!
If you replace this with small (carbo) blocks attached with line or a soft shackle the friction goes away. I have used this on my E27 for the last 5 years and can reef and un-reef from the cockpit in minutes with no help. I got the idea from a 32' Beneteau in the marina. A friend did this with his 30' Newport with the same success. When putting in a reef, the real trick is letting off both vang and main enough so the reef at the boom end is just as tight as the front. Oh, always reef or un-reef going upwind on the same tack - the reefed sail cloth always falls on the same side.
