light24bulbs
E30+ 1984, San Juan Island, Wa
Some of you may remember me as the fellow who recently bought a nice looking Ericson 30+ 1984 in Seattle and had 20 questions about it. Here's two more:
On the way to the yard for haul out, it started leaking about 1-2 shot glasses of oil an hour from the rear main seal.
Has anyone had this repair done to their m-18 and could maybe give me an idea of a reasonable cost. Seattle (not my home city) is often stupidly expensive and I have a hard time telling if I'm paying boat prices or sucker prices. They have to pull the motor for this and I suspect that may even involve taking part of the galley sink cabinet apart to get the motor out. Is that right?
This motor has I think around 8000 hours total time and exactly 2000 since rebuild. That's a lot. Below this point I start asking about repowering instead, and if you think I am being naive in talking about that, just skip reading below and call me out.
Would any of you be considering simply taking the plunge on repowering with a beta marine 16hp or what-have-you? The folks that do that around here are over in Port Townsend which is not impossibly far even with the oil leak and the motors don't even seem that pricey at a little under 3k (which I think includes the transmission), although I'm sure it's the labor and custom mounting/adaption that gets you in the end. The current motor is still strong and starts up straight away. Compession appears perfect although I haven't checked. As far as I can tell, there's not much really "better" about the beta motor technology wise, especially given that it is a low pressure injection / not common rail, very traditional diesel tractor motor. It simply would have less hours and that means less future, expensive problems in my mind. Might even be able to avoid the god-awful emissions stuff like a DPF, not sure.
It's pretty high current where I sail in the San Juans, often 3 knots average on a passage, going on 5 or 6 knots in the tight spots. Going from 40 year old motor that probably doesn't still quite make 14hp to a solid 16hp or even the three-cylinder 20hp would probably not be regretted. I have very little time on my new boat so I'm open to advice by those who know this boat and motor better than me.
PS. Why the motor only started to leak under way and not during prepurchase inspection, or during the hour or so of running in gear while I replaced the impeller, zinc, cleaned heat exchanger, changed all filters, and replaced half the hoses, but there you go. To think I could have had all that done with the engine OUT...sigh
