The return of the Bronze Age
To echo several great threads about valves and thruhulls on this site, Ericson was using RC Marine "marlon" VALVES screwed onto thruhulls and/or elbows in the 80's. These products were, by that time, distributed in this country by Forespar, after being previously distributed here by RC Marine directly.
Screwing a valve onto a threaded thruhull was and is considered a weak method of attaching it. This is so no matter what material the parts are composed of... whether reinforced nylon ("marlon") or bronze.
Ericson Yachts could have installed the RC Marine seacock version with three bolt/screw base attachment to the backer or hull, but for some reason chose not to do so. I do not see where they saved any time or inventory, but then I never build boats for a living, either... :nerd:
Using the flange-base version would have solved the first concern of whether the screw-on-valve device was a real seacock, and it was not.
The second problem of the early RC Marine composite was that the ball was mildly hydroscopic and would... slightly swell... and become hard to rotate. The good news is that the valve body is strong and that the weak point then moved to the valve shaft. Bad news is that you still have to replace the valve, after the handle would break off.
Regular lubrication helps a lot, and if you are real careful, it is quite possible to take the valve off the boat and with a large wrench and gentle force back off the nut on either end and veeerrryyyy slightly increase the clearance around the ball by a gnat's eyelash.
In the real world, whether you have a 20-30 year old gate valve, a taper-plug metal valve, or an early marlon valve, it is time to upgrade. Like all the hoses on your boat and most of the wiring, etc, etc, and more etc.... specs and engineering changes and (sometimes!) advances.
There are many pictures in other seacock and thru hull threads of this fine site of the new-design Forespar and the Groco (and equivalent bronze products) ball-valve flanged seacocks. Any choice you make has real pluses and minuses.
The only part of threads like this that is a tad disturbing is the wholesale dissing of one old product over another. After all, the whole darned boat is made out of reinforced composite, i.e. "plastic." A new thread about replacing the entire hull with bronze would certainly sharpen the focus, by the way.
