mark001
Hi,
I purchased my E36C recently and have had some repairs done that were recommended by the survey report. One of these repairs was to replace the cutlass bearing and re-glass around the P-bracket which I had professionals do. We put the boat back in the water today and now I have noticed a leak around the top of the shaft (under the aft bunk) which I believe is the packing. It has been on hard stand since I first saw it so I had not seen it in the water before so do not know if it leaked before. This is a bit of a worry, how hard it that to fix? Will I need to haul out of the water again?
Adding to the concern, I have an intermittent fault with the wiring that has only become apparent when we moved the boat that causes all power to be lost including the BILGE PUMP! When this happens if I reach in behind the DC panel and jiggle a wire it comes back. I spoke to an electrician and he said it will be difficult to fix because it is hard to get to (there is also evidence of melting on one of the wires so possible loose connection causing arcing).
I am supposed to be leaving the boat in the marina for 2 weeks as I return to work (5hrs drive away) and then coming back to sail down. Bit concerned to leave it though with possible loss of bilge pump.
Another minor annoyance is that the Australian authorities say that the gas system does not have an "Australian Certification" and so must be removed so now I have no fridge, no stove, faulty electrics and a leaky boat. But its MY boat....and its an Ericson!
