PANorth
A few days ago we discovered diesel in the bilge of our E38. We removed the battery (forward of the fuel tank under the quarter birth) to find a slow-drip rate of flow coming from under the fuel tank. The rate is about 1/2 gallon a day, which is what we are removing from the bilge. We cleaned the tank a year or so ago while the boat was on the hard. There was no sign of corrosion at that time. The tank sat empty until a month or so ago when we were approaching splash time. We assume the leak is a fitting or a weld. She went back into the water a couple of weeks ago.
There are no visible leaks to be seen through the hatches to the tank. So we seem to need to cut into the bunk to see the nature of the leak. I started to remove the trim around the bunk but realized that the bed of the bunk was probably the first thing to go in. We would need to disassemble a good part of the cabin to get to the tank. I'm thinking that we should just cut through the bunk around the tank, removing just enough to see all sides of the tank. Then, assuming we don't need to remove the tank, we will screw support boards under and around the opening (there is probably a term for that but I don't know it) to attach the piece of wood we took out.
Has anyone had to deal with this? How did you approach it?
