What do you use to protect jib sheets from chafing on the shrouds while the boat is at rest? Underway, on our boat they pretty much stay clear of the shrouds. Our current plan is to secure the furled jib by tensioning the sheets against the locked furler. When the rigger put in our new standing rigging he ditched the plastic tubes that came with the boat. The rig is up though I could detach each spreader to slip something on. I think we could get by with protection on just the main shroud.
My half-axxed solution after we got new sheets last fall:
PVC pipe, slit and secured?
Dyneema sleeves sewn to the sheets? Would those be in the way on the winch?
Commercial velcro sleeves put on the lines only while at mooring/anchor?
Remove the sheets and secure the jib with sail ties?
Pros and Cons?
Pros and Cons?
