A little thermodynamics anyone ?
John,
I thought I should respond to your mention of "retain heat". Actually the icebox insulation goal is a bit more complicated. Its really about protecting the icebox cold spot from the surronding heat energy.
Here's something close to what I just emailed to the Ice Saver Blanket people to clarify an inaccurate statement on their website claiming reflection of cold:
The compressor is pumping the heat energy out of the frig and you want to protect the colder area that the compressor just made from any heat energy flowing back in. That's where the insulation comes in. Heat travels by three means: convection, conduction, and radiation. The shiny foil reflects the radiant heat away. Foam insulation, bubble pack, or in the best case a vacuum panel prevent conduction of the heat. That just leaves convection, which is reduced by preventing the flow of warmer air into the frig with a good seal. For instance if one leaves the drain open, cold air, being denser, will sink by convection to the bottom of the frig and seep out the drain, sucking warmer air into the top of the frig and reducing the temperature of where the drain leads. That can be prevented by plugging the drain and having a good seal on the frig door. There would also be heat flow effects at the uninsulated drain where the heat below the frig flows into the drain area.
Finally, every time the frig is opened, the air is stirred by turbulence of the lid and some warm air mixes with the cold air in the frig, displacing some cold air to the cabin and leaving some of that nasty warm air with its heat energy in the frig !
So anyway, the auto windshield shade double sided foil bubble pack sandwich is not only a heat reflector, but an anti-conductive insulator with the bubble pack. Home Depot sells a thin insulation from Reflectixinc.com in rolls which is the same as the auto windshield shade with foil on the outer sides and bubble pack inside. The R values range from R4 to about 20, depending on the thickness. I just realized that I have a roll of the R12 stuff that's only about 1/8" thick. Besides being inexpensive and thin, it's water proof, so it will make a good inside the ice box retrofit liner. Since it's inexpensive, if it gets damaged over the season one can make another with a pair of scissors relatively painlessly.
Maybe I can install it this week. I don't plan to do any extended battery drain tests, as I already had a pair of batteries assasinated by a few transient slipmates knocking our power cord loose last year with our frig running. That brings me to another must have improvement: a low power cutoff switch for the 12 volt distribution.
jkm said:
Very good suggestions from all.
I visited the web site then realized that the aluminum sheets sandwiched around bubble wrap is really to retain heat. I've used a product by a company named Reflectix (Reflectixinc.com) to wrap hot water tanks and it is a very good product to retain heat.
Any thoughts?
John
