wurzner
Anothe fellow in my marina purchased a 1989 Ericson 38-200 and has found what may be a fairly significant issue. During the process of decommisioning the boat, the straps from the hoist made a portion of the rubrail come loose and sag. After removing it to inspect how to repair, it became evident that the hull to deck seam is opened up for approximately a 10 foot section. To fill this area, there is a fair amount of caulking that is now old suggesting this is an old repair.
The questions I said I'd ask for him is how do you determine if the separation continues to the inside since this is an inward seam. I can't imaging what would cause the inner layers of glass to separate suggesting this may just be at the exterior and that the interior seem is still in place.
Is there a risk of significant core damage due to the ingress of water?
How does one pursue doing a repair of this nature?
Can this just be caulked up and the rubrail reattached? This condition is not noticable when the rub rail is in place.
Does this pose a structural issue the a TAFG system? If all the loads are transferred to the keel and TAFG, I wouldn't think too much load is applied to the hull to deck seam. The area we are talking about is from about the mast going 10 feet back or so.
thanks for any input. I believe he is planning on just caulking for the immediate time being, using the boat, and developing a strategy to address this going forward. I'm interested in replies since I also heard about a 1981 38 that had the same issue. My rubrail is dented in a few localized places and am curioius to see if removing it and rebedding the entire hull to deck seam is a good idea.
thanks
shaun
thanks
shaun
