Hull Speed E-25 C/b??
briangsmith
don't seem to find this anywhere in the specs/manual-
she seems to sail well in 15 k winds up to a speed of
4, 4 1/2 knots- motors in this range well (outboard)
as well- but can i get more??
bgs
Hull speed is 1.35 times the square root of the waterline. You can figure your potential from that. I have an E-27 that routinely sails above five knots in 10 knots of wind, so it would seem to me that 4 to 4.5 is below the potential of your boat. Of course, I am assuming that your sail trim, sail condition, angle of heel, rudder angle, amount of board in the water is perfect for your point of sail.
Morgan Stinemetz
Guy Stevens
How did you measure the boat speed?
There are a couple of ways to go wrong in measuring.
1> Using anything resembling a knotmeter. Simply not very accurate most of the time.
2> Calculating boat speed while a current is present.
3> Not looking through the cocktail or beer glass at the indicator, whatever flavor it is.
Most people are able to get their boats up to at least 4 times the square root of the waterline if they use a cocktail or beer glass for a viewing filter :)
Seriously you should be going between 1.1 and 1.4 times the square root of the waterline of your boat. But before you check everything that you are doing sailing it, check the measuring device and conditions that you are using the measuring device under.
Guy
Bob in Va
calculated
Your hull speed is 6.1 kts, ref: www//image-ination.com/sailcalc.html of course you can exceed it for limited periods surfing, etc., but I suspect if the bottom is clean and sails decent, you can see this number by GPS under the right conditions for extended time spans.
