Help with Ericson23 replacement parts...
rbaroni
View attachment 2668Just purchased an E23. At the bottom of the mast is located a metal sleeve that appears to be brass or similar, where the steel pin attaches the mast to the mast stand. The sleeve is worn and needs replacing. Any idea where I can get a replacement? Also, the bow caps, (not sure what these are called) are damaged and need replacing, any ideas? And a section of rubrail or all of it, I read the thread on rubrails, and it looks tough to find. I just need the rubber insert. I've attached pictures. Thanks in advance, I appreciate the help.
Bow casting replacement idea
rbaroni,
Check out the May/June 2007 issue of Good Old Boat. Page 17 has a how-to article on making a replacement "bow trim casting."
