The Whaler gusher manual pump for pumping out the holding tank gave way, and I need some advice on repair/replacement. Specifically, the handle attaches to a bolt which goes through the diaphragm which is sandwiched between two clamping plates (according to the diagram). The whole thing is held together by a nut, which seems to have loosened and fallen off into the bottom of the hull (ie. non-retrievable). Can someone advise if this is simply a matter of buying a replacement stainless steel nut and reassembling it, or is it a special part, or are there other considerations?
Any advice or help is appreciated.
Frank.
Frank.
