Galvanic isolator on an Ericson 381 (5-minute video)
dhill
This will be published eventually and correction appreciated if necessary.
Thanks for the video Christian! I purchased the same unit. The Ericson 35-3 has the same problem with the propane locker getting in the way. I have been considering trying to work around it by mounting it in the stern lazarette, but your solution may be my eventual result.
Dave
Same model I had installed last season. It’s mounted on the cubby wall in the quarter berth, just below the dorade box. A very wise investment for anyone connected to marina shore power regularly. As an aside, the prop shaft zincs I installed in Spring of ‘22 are at about 80 percent according to my diver. Some marina neighbors without an isolator go through theirs much quicker.
