My fuel tank on E-29 #370 Holdfast needs cleaning. Anyone have suggestions on the best method? It had not been used for 4 years before I purchased the boat and had about 3 gallons of very nasty gas I was able to remove with a hand pump. How is the tank bonded to the Hull? Is it worth the time and expense removing it so a radiator shop can clean it out or should I consider a new cross-linked polyethylene fuel tank? The engine is an A-4 Got it running after having the manifold welded to repair 2 cracks and rebuilding the carb. Had to skip the built in fuel tank and run from a homemade fuel supply to get some good gas into the engine.
Another question can pin hole leaks in the manifold be repaired with JB Weld? I still have one leak in that manifold.
