adam
Every time that I startup or turn off the engine (Atomic 4) on my Ericson 29, I have to remove the ladder, move things off of the cushion, and lift up or move the cushion before removing the engine cover in order to get to the fuel shutoff valve.
It would be so much more convenient, if I could turn on and shut off the fuel supply without having to move/remove all of that stuff.
Here are some ideas that I'm considering.
1) Cut a fist sized hole in the top of the engine cover, so I can reach down and get to the fuel shutoff valve without removing the entire engine cover.
2) Attach a metal rod to the handle of the fuel shutoff valve, and cut a small hole in the engine cover, so I can turn on or shut off the fuel supply by pulling or pushing that rod.
Any thoughts on those ideas?
And... any better ideas?
Thanks!
-Adam
Thanks!
-Adam
