Dave Rummens
This is a fresh water tank out of my E35-2 (1972) that was located under the V-Berth, near the bow. I had a larger capacity tank custom built so I want to sell this one. Ronco is the largest manufacturer of boat and RV Tanks. These tanks go new for $195. This one's in fine shape. See diagram for dimensions.
It has NPT threaded inlet, outlet and vent ports, and there are barbed adaptors inserted in each to attach to hose. Please note - the barbed adaptor for the outlet is broken off so you would need a new one of those.
Both the vent and outlet ports have a 1/2 inch barbed fitting that adapts to a 1 inch NPT threaded hole in the tank. You can adapt to whatever size hoses you have by purchasing 1 inch NPT to barbed adapters.
The fill port is located on the port side - on the side of the tank. It has a 1-3/4 inch NPT to 1-1/2 inch barbed adapter.
