Fixedlight Gasket Material
wheelerwbrian
I had Wefco Rubber make me some gasket material for the fixedlights in my 1988 E38-200 --these are the long Lewmar windows. The material is rubber so is suitable for use with the acrylic window material -- vinyl will cause the window to eventually craze.
Since it was a custom job, my cost for 25 feet (the minimum amount) was $150 ($50 for the gasket $100 for retooling). I only needed five feet of it for one window so I have 20 feet left, which would be enough for all four windows. Btw, it fit fine.
I'd be happy to part with it for cost, which would be $120. You can contact me via email at wheelerwbrian@yahoo.com
Here is a scan of the profile of the material to so you can verify that it will work for you.
