Fixed ports and water heater
Mike Anderson
Recently, Select Plastics installed new plastic in my fixed ports. I now need to install the ports in my 1988 E32-200. I have been told to use Boat Life Sealer and to try to keep the exterior frames a fraction of an inch off the fiberglass until the sealer sets up, then tighten the frames using the screws on the inside frame. Any suggestions on how to keep the exterior frames off the fiberglass or comments? Any advice on how to drain the water heater?
