Had an interesting thing happen inside our boat Thursday, 7-12. One of our fire bottles (5 pounder) decided to blow out its little O ring that seals between the valve assembly on top and the steel body.
It was not exactly "explosive" but while I was away from the boat for about 3 hours it had emptied completely and from the looks of things with some force. This was the one we have mounted in the aft cabin, adjacent to the galley and engine. Of course I have been doing quite a bit of maint. and upgrades lately and everything (!) inside is open with tools and parts all over. The side cover was off the engine area too....
When I opened the main hatch at about 5 pm, the interior, from the coutnertops downwards, was a ghostly white color! I could only see monochromatic shapes of my tools, gear and stuff. At first I thought I was having eye troubles, but each time I looked again it was still there!
It was kind of like looking out into your yard after a snow fall and marveling at the uniform cover and texture over... everything.
Soooooo, I ventured in. Aft cabin had powder about 1/8" deep on most flat surfaces. Main cabin coated likewise, but tapering in thickness toward the forepeak. Settee tops are well dusted and some light dust goes all the way to the ports.
Made a few phone calls Friday am to find that the powder is mostly "non toxic," but is mildly corrosive and could harm electronics. Right. That's nice. And the Statpower charger is mounted under that extinguisher, too.
Stopped by the Fein vac dealer and bought two packs of paper bags for our faithful little "robot" vac. Put vac out in cockpit and ran the hose down and started in.
Two full bags later I am about 2/3 thru with the worst of the obvious.
Looks like a week of wiping down and removing everything inside, bit by bit, to clean parts up. Even the tool box insides and all hand tools are coated.
Friday pm I visited the extinguisher company that has been certifying and (as needed) hydro-ing these bottles for me for over 15 years.
They say this situation is extremely rare. Speculation is that the two prior 100 degree days must have raised the pressure well over the standard 190 psi which would would stress the seal -- that and a suspicion that the valve was a bit over-torqued sometime in the past and maybe that over-tensioned the O ring seal. (?)
The company manager wanted to look at the extinguisher, and after one look told the counterman to go and get me a replacement one. I thanked him.
(A friend at the YC is a career fire fighter and looked at the mess and the bad extinguisher and said that he suspected improper assembly and that if I was polite I would likely get a free replacement.) He agreed that such a failure is very very rare. The bottle was a little over 20 years old.
All this narrative seems to prove only that you should keep up your inspections, and that the odds of this happening to you are probably too long to really worry about... But if it ever *does* happen...
Yikes!
:eek:
Pics do not show the guilty extinguisher, which mounts on the backside of the bulkhead by the galley range. Sorry; I was a bit preoccupied with the whole scope of the problem...
Damned good thing that almost all the cushions were at home the last several weeks...
Yikes!
:eek:
