Question about exit plates on the boom.
I’m running a jiffy reef system on my '75 E27. I plan to run the line internally through the boom (vs. externally) and run them back to the cockpit for single-handed reefing. I plan to use exit plates on both ends of the boom. Since there are enough machine screws inside the starboard side of the boom to make this “challenging”, I plan to run the reef lines along the port side.
My worry is a snagged line. All those screws worry me that they may snag the reef line at the worst of times. The machine screws all appear to be at least 3/4" long and stick farther into the boom than I would have guessed. The longest that they need to be is about 3/8".
Should I replace all the screws with shorter ones and round the ends to minimize snagging? If I had a 3-foot-long socket extension I would even consider acorn nuts… would there be an alternative? What about aircraft-quality blind rivets vs. machine screws? Are there any tips or tricks to running the line internally?
TIA
- Jerry
TIA
- Jerry
