Doug & Maile
we own a 1988 38-200 with the Universal 5432 engine. Above 1800 rpm with a temp of 150f we start seeing some steam which increases with increasing rpm. At 2200 temp will be 175-180. temps seem normal but we are concerned about the steaming. any ideas? in looking at the system we see a small diameter line from the exhaust riser that ends by tapping into the exhaust thru hull just prior to exiting the hull. we are concerned about the exhaust steaming at the exhaust exit point. is it normal if not, what might be the remedies. secondly is the above described cooling water configuration a factory install or ??.
Looking forward to your reply
Doug & Maile
Doug & Maile
