I recently had an Ericson 350 built by Pacific Seacraft (same as Ericson 34) under contract and had it surveyed. The surveyor found a small (8"x8") area below the waterline with high moisture readings and delamination. There are 2 thru-hulls in this area. He also noticed several areas inside the hull where the thickness varied, which he pointed out is a sign of a cored hull. I actually spoke with a guy that worked for both Ericson and Pacific Seacraft and he says the hull is not cored.
In short, I'm confused. Is it possible that the variations in hull thickness are just stiffeners that the builder added and not an entirely cored hull? Is it possible that the area of delamination and high moisture readings is just a void in the layup?
Or should I just assume that if it walks like a duck and talks like a duck, it's a cored hull?
Any insight or comments would be greatly appreciated!!!
