When we pulled our E28 at the end of the season, the prop was badly calcified, the area around the shaft and prop had calcified deposits on the hull, and the lower section of the keel was pitted. The shaft anode also showed signs of excessive pitting compared to previous seasons. Our fuel gauge was not working at the beginning of the season. About half way through the season, I replaced the fuel sender and also discovered that the ground wire to the engine was very loose and not making a connection. I believe that this wire also grounded the fuel tank. I have checked the ground connection from the prop/shaft to the positive side of the battery and it is grounded. No other boats near our slip showed this kind of problem. My question is: Was the loose ground from the tank the likely root cause of the electrolysis?
Jim
West Coast of Michigan
Jim
