Hello Ericonsites. So we've had this 34T for a full year now. In that time, somehow we managed to get the Reverse Polarity light to turn on, and can't get it to turn off. And now the latest, the DC panel is completely dead.
The amp meter next to the panel was reading dead batteries, so we took them out and had them tested. Fully charged on both. Put them back in, still dead per the meter read. None of the 12v systems work, bilge, blower, lights, all dead, as is the starter.
The heater runs direct off the battery from what I've seen, and it has power, so I'm leaning towards a fuse or the red battery master switch is dead. Is there a fuse panel somewhere that I'm missing, or is it just the inline fuses per each cable?
The only changes we've made to the electrical system is installing a Smart Plug to replace the standard shore power turd plug, and two of the cabin interior outlets. These are wired correctly per my Receptacle Tester.
This is a 1978 34T with an Atomic 4 engine and just the two batteries.
Thank you.
Thank you.
